ADC12 problem
aialinux
Posted on July 24, 2006 at 14:45
ADC12 problem
8 REPLIES 8
aialinux
Posted on March 19, 2006 at 21:22
I am using STR710 ADC12.The program as below:
ADC12_ChannelSelect(ADC12_CHANNEL0);
/* Start the Converter */
ADC12_ConversionStart();
/* Wait until the availabiliy of data in the specific flags */
while (ADC12_FlagStatus (ADC12_DA0)==RESET);
/* Get the conversion result from the correponding Data register */
ADC_Reg = ADC12_ConversionValue(ADC12_CHANNEL0);
But the program can't run out of : while (ADC12_FlagStatus (ADC12_DA0)==RESET);
aialinux
Posted on March 22, 2006 at 21:24
Yes! The problem is still the same.
It can't run out of : while (ADC12_FlagStatus (ADC12_DA0)==RESET);
ezanen9
Posted on March 27, 2006 at 05:54
Just a suggestion: did you set the ADC_en bit in the PCU_BOOTCR register?
If not the ADC will not run and the sample ready flag not set.
Jimmey
gawied
Posted on July 19, 2006 at 09:05
Hi Dom
Did you solve the ADC12 problem? If so please let me know what was wrong, as I am getting the same problem - not every time though, which makes it even more scary ;-).
Cheers
Gawie
gawied
Posted on July 21, 2006 at 05:46
Hi
I solve my problem, but I am not quite sure of my solution. Maybe somebody can shed some light on the issue.
On startup I did initialise the ADC by calling the following functions:
// Configure the used analog input to HI_AIN
GPIO_Config (GPIO1, 0x0001, GPIO_HI_AIN_TRI);
// Initialize the conveter register.
ADC12_Init();
// Configure the ADC prescaler to have a sampling frequency = 500Hz
ADC12_PrescalerConfig(500);
// Select the conversion mode=single channel
ADC12_ModeConfig (ADC12_SINGLE);
And when ever I want to get an ADC value I did a few (100 or so) conversions and then calculated the average. I called the functions as follow:
// Select the channel to be converted
// Start the Converter
// Wait until the availabiliy of data in the specific flags
while (!ADC12_FlagStatus (ADC12_DA0));
// Get the conversion result from the corresponding Data register
My problem was that the flag, indicating that the conversion was completed, was not set on some occasions.
I fixed it by doing the init routines not just at startup, but also every time I wanted to do an ADC conversion. Does this make sense and do I have to init the ADC before every conversion?
Any comment would help ;-).
Thanks,
Gawie
hichem2
Posted on July 21, 2006 at 13:01
Normally you don't need to initialize the ADC before every conversion, please could you tell me wich library version you are using and check the
ADC12_Init(); funtion body .
cheers,
Hich
gawied
Posted on July 21, 2006 at 18:11
Hi
I am using libary ver 3.1 and the ADC12_Init() looks like follows:
void ADC12_Init(void)
/* Initiate ADC12 registers to their reset values */
ADC12->CSR = 0x0000;
ADC12->CPR = 0x0005;
Cheers
Gawie
gawied
Ok, I solved my problem!
I had more than one channel selected in ADC12->CSR while I was using the ADC in single conversion mode and that was the cause why the completion flag was never set.
Cheers
Gawie
