ADC problem!
aialinux
Posted on February 13, 2006 at 06:32
ADC problem!
aialinux
Posted on February 12, 2006 at 22:03
I am using the ADC in STR710 chip. When P1.0 is 1.00V
I want to know the converted value stored in ADC_DATA[0].
The STR710 ADC is different to other MCU.
I am not so clear to it's principle.
How to calculate the converted value when AIN0 has voltage 0--2.5V.
[ This message was edited by: dom on 13-02-2006 02:34 ]
hichem2
Hi dom,
While the analog modulator is critically important in determining accuracy of a sigma delta ADC, digital software calibration techniques are essential for reducing offset and gain errors, as well as improving linearity.
The converted value stored in ADC_DATA[n] is a signed two’s complement.
To calibrate the converter, it’s necessary to apply the minimum and maximum inputs supported 0V and 2.5V. The digital output for a 0V input is the offset.
The offset and gain correction factors calculated by software can be stored digitally and applied to all outputs from the converter.
Note: You can find with the STR71x software library package (available on the web) an example of how to use the STR71x ADC 12 converter in single channel mode.
Hichem
