access to external ram
jm
Posted on February 25, 2004 at 12:57
jm
Posted on February 25, 2004 at 10:06
I work on ST10F168 and i use 2 64K*8bits SRam chip like one 64K*16bits Sram chip.
My problem is that i don't understand to use BHE and A0 signal.
I find 2 configurations :
1) WR signal on WR of first chip
BHE signal on WR of second chip
CS1 on CS of 2 chip
Adress A1->A16 on A0->A15 of 2 chip
First chip data : low (POL)
second chip data : high (POH)
2) WR signal on WR of 2 chip
BHE signal on CS on first chip
A0 signal on CS of second chip
adress P1H on A8->A15 of first chip
adress P1L on A0->A7 of second chip
Second chip data : high (POH)
So, i don't see the difference between the 2 configurations !
If someone can explain to me the differences or advantages.........
regards,
Jim
charles239955_st
Posted on February 25, 2004 at 12:35
Hello.
In the St10 BUSCON register you have a lot of configurations possible. And it is also related to the SYSCON regsiter bit 7: WRCFG. With this bit you select the way the pins /WR and /BHE are working.
1/ If WRCFG = 0, you have the pin /WR = write and /BHE = byte high enable
This corresponds to your configuration 2 below.
The /WR signal is always connected to the 2 SRAMs. When you need to perform an 8 bit access, ''chip select'' will enable the correct SRAM.
For the high byte, the chip select signal is /BHE, for the low part it is A0 address line.
2/ If WRCFG = 1, the pin /WR is the signal /WRL = write low
and the pin /BHE is /WRH = write high.
This corresponds to your configuration 1. The CS always enables both SRAMs but for 8 bit write access only 1 SRAM get an active write signal.
The selection between the 2 modes depends on the SRAM you have because the timings are not the same in the 2 cases: check the need of your SRAM with regard to CS active before/after Write signal. Have a look to the datasheet AC timings part where you have chronograms for the signal.
Also your configuration 2 can not be used if you have several devices on the external bus because the SRAMs may answer for any read/write action as the chip select in not based on a window range.
I hope I helped you.
Kenshin
jm
thanks for your precision !
