About operating voltage of ST_M24512-r.
TKron.1
We would like to confirm questions below.
ST_M24512-r
1. Do you have datasheet for information about SCL speed and minimum Vcc?
2. Is our understand correct that the minimum Vcc of ST_M24512-r is 1.8V with our using SCL
400 khz ?
3. Related no.2. How much voltage margin from 1.8 V minimum?
https://www.st.com/resource/en/datasheet/m24512-r.pdf
VIL / VIH in the data sheet
TKron.1
thank you for information
