2007-04-09 05:38 AM
2011-05-17 12:40 AM
Hi
i run programs from the ram. i need to disable nested interrupts. i did this in 91x_vect.s but whenever an interrupt occurs the program control goes to a specific flash location that looks exactly like the original 91x_vect.s. right now the flash has a simple program with the original 91x_vect.s what should i do to make changes in the 91x_vect.s to take effect. thanks vikram
