API to Read from Flash
Santhamurthy R
Posted on May 29, 2017 at 13:33
Hello All,
 I am working on SPC560B54L5 board using SPC5studio version 5.2.3.
I can able to write to C-flash memory using Flashprogram() api of flash driver component. In addition to that I also want to read byte by byte or stream of bytes from the C-flash memory. Referred to the 'Standard software driver for C90LC Flash' document I couldn't found any API to read from flash memory.
kindly suggest how can I read from flash using the flash driver component.
Thanks in Advance,
with Regards,
R.Santhamurthy
Erwan YVIN
Posted on June 14, 2017 at 15:26
Hello ,
we did not implement a read function.
you should point to the memory address that you want to read to get data back, without any kind of operation on flash controller.
         Best regards
            Erwan
2 REPLIES 2
Erwan YVIN
Hello ,
         Best regards
            Erwan
Posted on June 23, 2018 at 10:51
Hello Erwan:
        I don't quite understand about the flash “margin readâ€� and “ array integrity checkâ€�,where do the functions need ?  Do we need to use this function at  the normal program?
Best regards
MMWang
