SPC58 StandbyMode : How to enter standby mode?
hans536
I use spc58nh-disp develop board.
I want to enter the standbymode. but can't enter.
If i setup SPCSetRunMode(SPC5_RUNMODE_STANDBY0) in main loop, It's behave.
But after i get the RTOS, core0, core1 and core2 working, If i work SPCSetRunMode(SPC5_RUNMODE_STANDBY0), is not working.
what is problem?
ex)
--> standby mode working code
int main(void) {
componentsInit();
wkpu_lld_start(&WKPUD1, &wkpu_config_wkup_cfg);
if (SPCSetRunMode(SPC5_RUNMODE_STANDBY0) == CLOCK_FAILED) {
SPC5_CLOCK_FAILURE_HOOK();
runCore0();
runCore1();
vTaskStartScheduler();
  for ( ; ; ) {  }
--> standby mode not working code
int main(void) {
componentsInit();
runCore0();
runCore1();
  for ( ; ; ) {  }
Erwan YVIN
I recommend to use this application (for STOP mode)
SPC58xHxx_RLA WKPU Test Application and customize for your device (STANDBY)
1 REPLY 1
Erwan YVIN
