What is the vibration frequency range that the sensor can successfully detect?
Options
‎2023-05-19 5:34 AM
Q&A - webinar "In-sensor monitoring with intelligent MEMS sensors"
Labels:
INEMO-Inertial Modules
Options
‎2023-05-19 5:53 AM
The output data rate of the sensor goes up to 6667 Hz, however the actual bandwidth of the sensor (-3dB point) is around 1.0 kHz.
1 REPLY 1
Options
‎2023-05-19 5:53 AM
