2021-05-11 01:00 AM
There are two parameters "Speed" and "Acceleration Peak" in time domain (using MotionSP library). What condition (e.g. frequency 10Hz - 1kHz use speed and Above 1kHz use acceleration peak) will be used Speed in time domain and Acc Peak in time domain? Please advise. Thanks!
2021-05-11 01:50 AM
Hi @JTam.1 ,
you can choose the thresholds for the different values in MotionSP_Threshold.h file included in \Projects\STM32F446RE-Nucleo\Demonstrations\Predictive_Maintenance\Inc.
Hope this helps.
Niccolò
2024-03-28 04:37 AM
I am working on a similar project based on MEMEs sensors so, so i want to know how you calculated acceleration and velocity. Please give us a whole process of finding this parameter with each and every step with an equation if comes. And if you have any documents regarding how to calculate acceleration and velocity.
I am using this two sensors for measuring acceleration and velocity.
1)LSM6DSOX
2)IIS3DWB
