Sensor Fusion output parameters.
RBAGU.1
Could you recomend me a document that speaks about the format of the matrix parameters obtained trought sensor fusion? For example: linear_acel, quaternion...
Best regards.
Eleon BORLINI
Hi @RBAGU.1​ ,
are you referring to the MotionFX library of the X-CUBE-MEMS1 FW function pack?
If so, please have a look to the User manual UM2220: MotionFX library, where the various functions called in the library are described.
Let me please know if this can help you.
-Eleon
Eleon BORLINI
Hi @RBAGU.1​ ,
-Eleon
RBAGU.1
Many thanks. Best regards.
