Please help me with the difference between LSM6DSOWTR and LSM6DSOTR
ACHAN.11
Please help me with the difference between LSM6DSOWTR and LSM6DSOTR urgently
Andrew HURMAN
Axia hi, The LSM6DS3 and all its variants are 2 generations of device older than the LSM6DSO. The DSO performs much better.
9 REPLIES 9
Eleon BORLINI
Hi @ACHAN.1​ ,
please consider that the correct part number name is the LSM6DSOTR.
The LSM6DSOWTR denomination doesn't exist, or, better, is not a mass-market name, as you can check if you search the two part numbers on the ST eStore at this link.
For example, Arrow and Mouser distributors points either to the LSM6DSO, or to the LSM6DS3TR-C when searching for LSM6DSOWTR.
Hope this can help you.
-Eleon
anne
LSM6DSO andLSM6DS3TR-C differerce?tks
anne
Andrew HURMAN
hello,andrew,LSM6DSRTR,LSM6DS3TR-C,LSM6DSOWTR ,these three items are same generation?LSM6DSRTR and LSM6DS3TR-C are altervative? or LSM6DS3TR-C and LSM6DSOWTR? we can not find LSM6DSOWTR data sheet.
LSM6DSO can replace LSM6DSRTR,LSM6DS3TR-C,LSM6DSOWTR ,right?tks.
Axia hi,
Please share your email in private message and we can discuss together.
The LSM6DSOW is a customer device so no datasheet is available.
The -C is for a specific Chinese customer so also not really available in a sustainable form.
The Current generation are the following:
LSM6DSO and LSM6DSR
Anything else you have mentioned is old but ALL are P2P compatible, however significant S/W changes will be required.
Andy Hurman
ST Microelectronics
FAE and Market Development Manager
UK and EIRE
0447802 461034
ST Restricted
anne
Dear andrew
0693W00000QKibkQAD.pngPLS help us which conditon this item connect with VDDIO or GND?by the way,my e-mail adress is purchase@zeuselectronic.com,we need more help for this item,tks.
anne
Dear Andy Hurman
         pls check the following Pic ,this is pin description of part LSM6DSO,would you please help us
which conditon pin 2 and pin3 should be connected  with VDDOR ?which conditon pin 2 and pin3 should be connected with GND? or either of VDDOR and GND is ok?
anne
深圳市宙斯科技开�?�有�?公�?�
Shenzhen Zeus Technology Development Co., ltd
TEL:86755-26961892 FAX:86755-26229216
Hi @anne​ ,
please find here the Community feedback about your request.
-Eleon
