2021-03-19 2:14 AM
Please help me with the difference between LSM6DSOWTR and LSM6DSOTR urgently
2022-07-04 8:41 AM
Axia hi, The LSM6DS3 and all its variants are 2 generations of device older than the LSM6DSO. The DSO performs much better.
2021-03-19 2:40 AM
Hi @ACHAN.1 ,
please consider that the correct part number name is the LSM6DSOTR.
The LSM6DSOWTR denomination doesn't exist, or, better, is not a mass-market name, as you can check if you search the two part numbers on the ST eStore at this link.
For example, Arrow and Mouser distributors points either to the LSM6DSO, or to the LSM6DS3TR-C when searching for LSM6DSOWTR.
Hope this can help you.
-Eleon
2022-07-03 8:45 PM
LSM6DSO andLSM6DS3TR-C differerce?tks
2022-07-03 8:46 PM
2022-07-04 8:41 AM
2022-07-05 8:50 PM
hello,andrew,LSM6DSRTR,LSM6DS3TR-C,LSM6DSOWTR ,these three items are same generation?LSM6DSRTR and LSM6DS3TR-C are altervative? or LSM6DS3TR-C and LSM6DSOWTR? we can not find LSM6DSOWTR data sheet.
LSM6DSO can replace LSM6DSRTR,LSM6DS3TR-C,LSM6DSOWTR ,right?tks.
2022-07-06 5:11 AM
Axia hi,
Please share your email in private message and we can discuss together.
The LSM6DSOW is a customer device so no datasheet is available.
The -C is for a specific Chinese customer so also not really available in a sustainable form.
The Current generation are the following:
LSM6DSO and LSM6DSR
Anything else you have mentioned is old but ALL are P2P compatible, however significant S/W changes will be required.
Andy Hurman
ST Microelectronics
FAE and Market Development Manager
UK and EIRE
0447802 461034
ST Restricted
2022-07-10 6:47 PM
Dear andrew
PLS help us which conditon this item connect with VDDIO or GND?by the way,my e-mail adress is purchase@zeuselectronic.com,we need more help for this item,tks.
2022-07-15 5:58 AM
2022-07-18 3:26 AM
