2019-02-13 11:09 PM
Hello all,
We have interfaced LSM6DS3 with a wireless microcontroller by I2C for .
I want to know how do I select the best ODR value?
Is there any standard methods for selecting ODR?
According to datasheet I found that if ODR is high the current consumption of the sensor is more if it less the current consumption is less, expect this is there any parameters will affected by changing the ODR?
In gyroscope Bandwidth selection LPF2 cut-off frequency depends upon ODR selection? What is it mean?
Thank you
D.Vishnu
2019-02-14 12:04 AM
Have you heard of the Nyquist theorem ?
That depends on the signal bandwidth you want to cover (know & react upon) in your application.
2019-02-14 1:57 AM
Hello AvaTar,
Yes I heard of nyquist theorem, but I don't have an idea how it will be applicable here.
Say If I have selected 52Hz as my ODR the digital LPF cut-off frequency is 15.8 Hz(3.8 chapter, page no 13, application notes), Is that mean now my bandwidth is 15.8 Hz.
If possible please explain this part of section in the document.
Thank you for your time.
D.Vishnu
2019-02-14 2:06 AM
What part ?
It is just the introduction, naming device properties.
Cut-off frequency is another specific term, elsewhere called -3dB frequency.
2019-02-14 2:24 AM
In the document (page no:30 chapter 3.8)
2019-02-14 3:31 AM
Not sure what is unclear there.
I think here is not the place for an introduction to the theory of electrical engineering and alternating voltages.
The bandwidth is a requirement for your device you want to build.
For a gyroscope, supposedly the turn rate and the angular resolution you want to measure, and the sample rate.
