ISM330DLCTR not available in the market? Any alternate part?
‎2020-10-28 5:23 AM
Hello.
I don't see ISM330DLCTR in stock anywhere? Is there any alternate part. I can see LSM6DSM. Will it work with same software. Any suggestions?
Thanks,
Kumar
INEMO-Inertial Modules
‎2020-10-28 7:10 AM
Hi @NK.1umar Byregowda​ ,
if you are looking for a substitute of the ISM330DLCTR device for industrial vibration monitoring application (as for example the substitute for the device on STEVAL-BFA001V1B kit), I can give you a couple of suggestions on the state-of-art for this purpose:
- IIS3DWB, which is a pure accelerometer, if you don't need the gyroscope data: this is the vibration sensor on the SensorTile Wireless Industrial Node STWINKT1;
- ISM330DHCX, which is more similar to ISM330DLCTR and can be considered a pin-to-pin and firmware compatible substitute. This is also present on the STWINKT1 board.
You may found little stock for ISM330DLC part number (HERE), but I would however suggest one of the two above options for long run projects.
-Eleon
‎2020-10-28 7:10 AM
-Eleon
‎2020-10-28 8:36 AM
Thanks Eleon. I have ordered few from suppliers. I will do experiment with IIS3DWB.
Kumar
