I would like to measure the pressure of a tire (size of a bicycle) in a robotics application. I am thinking of using LPS25HTR sensor to measure the pressure. What would you suggest in mounting this to get a proper pressure reading?
Options
2020-10-26 2:06 PM
If the LPS25HTR module is not the right device, would you something more appropriate?
Labels:
Environmental Sensors
1 REPLY 1
Options
2020-10-27 8:13 AM
Hi @KDao.1 ,
it depends on the maximum pressure you want to measure.
Please note that ST pressure sensors range is up to 1.26 bar, and the typical pressure of a tire can be more than 2 bars...
Do you have such a constrain in your application?
-Eleon
