2021-05-17 01:28 AM
Can I know how can I set this value in terms of Force or Pressure?
Like the representation of this value in terms of force or pressure??
2021-05-17 02:53 AM
Hi @SANAN.1 ,
I believe you should multiply the voltage value for the sensitivity (usually expressed in Pa/V or in N/V for an analogic pressure or force sensor), that is usually reported in the sensor datasheet.
By the way, which ST sensor (part number) are you using?
-Eleon
2021-05-17 03:52 AM
I am using Piezo Sensor to get the Hpatic Feedback
2021-05-17 03:53 AM
Haptic*
