2021-03-03 08:20 AM
2021-03-03 09:26 AM
in case of highly dynamic conditions, to obtain the best results it is suggested to consider the dynamic inclinometer solution. Dynamic inclinometer rely on the usage of accelerometer + gyroscope + sensor fusion software. ST propose the 6-axis IMU ISM330DHCX + the MotionDI software library for this application, example implemented in X-CUBE-MEMS1 SW package in st.com
2021-03-03 09:26 AM
