2021-05-10 08:22 PM
I use IIS3DWB vibration sensor. I set maximum bandwidth 6.3 kHz and FFT size 2048. What acquisition time should I use when using MotionSP library?
2021-05-11 01:38 AM
Hi @JTam.1 ,
I would say that you need at least 2x6.3 ksamples to respect Nyquist, , so with an ODR of 26.667 kHz you would need half a second per acquisition.
Niccolò
2021-05-11 01:07 AM
Hi @JTam.1 ,
what ODR are you working with?
Niccolò
2021-05-11 01:15 AM
The ODR of IIS3DWB vibration sensor is 26667 Hz with bandwidth 6.3 kHz.
2021-05-11 01:38 AM
Hi @JTam.1 ,
Niccolò
