Dear Sir Some problem with reading lsm6dsl
EOved.1
I am using lsm6dsl , I need to read the reg who_am_i , I issue the read register every 1 sec , CS is OK , CLK is OK. I get the correct answer only on power up .
Attached 3 pics ,
EOved.1
Hi Ignore this question solved
niccolò
Hi @Community member​ ,
the read command seems fine, so let me ask you some questions to better understand the situation:
are these three plots consecutive reads?
did you try to read/write other registers consecutively?
what happens between those reads in your code or on your hw?
did you change some registers value to 00100100 in your code?
Niccolò
can you tell me how you managed to solve it?
it can be helpful in the future for other users with a similar problem =)
Niccolò
