How to choose the right total acquisition time?
JTam.1
I use IIS3DWB vibration sensor. I set maximum bandwidth 6.3 kHz and FFT size 2048. What acquisition time should I use when using MotionSP library?
Hi @JTam.1​ ,
I would say that you need at least 2x6.3 ksamples to respect Nyquist, , so with an ODR of 26.667 kHz you would need half a second per acquisition.
Niccolò
niccolò
Hi @JTam.1​ ,
what ODR are you working with?
Niccolò
The ODR of IIS3DWB vibration sensor is 26667 Hz with bandwidth 6.3 kHz.
Hi @JTam.1​ ,
Niccolò
