How config IIS3DWB to FIFO mode with Watermark?
uilter
Hi, I'm trying to use the IIS3DWB as FIFO mode with a watermark.
I'm using a custom board. I double checked the hardware and guaranteed this board works well. I'm able to read/write the sensor using SPI interface and generate interrupt with wake-up int source.
To handle the sensor, I'm using the library created by ST. https://github.com/STMicroelectronics/iis3dwb
In this mode the interrupt INT1 not works well. This is my init code:
// Reset the sensor
iis3dwb_reset_set(&hAcc, PROPERTY_ENABLE);
do
    iis3dwb_reset_get(&hAcc, &reset);
    HAL_Delay(BOOT_TIME);
} while (reset);
iis3dwb_xl_data_rate_set(&hAcc, IIS3DWB_XL_ODR_26k7Hz);
iis3dwb_xl_full_scale_set(&hAcc, IIS3DWB_2g);
iis3dwb_fifo_mode_set(&hAcc, IIS3DWB_STREAM_MODE);
iis3dwb_fifo_watermark_set(&hAcc, 256);
iis3dwb_fifo_xl_batch_set(&hAcc, IIS3DWB_XL_BATCHED_AT_26k7Hz);
iis3dwb_block_data_update_set(&hAcc, 1);
int1_route.fifo_th = 1;
int1_route.fifo_ovr = 1;
int1_route.fifo_full = 1;
int1_route.fifo_bdr = 1;
iis3dwb_pin_int1_route_set(&hAcc, &int1_route);
Please, could you guide me to find where is my mistake?
If possible, can anyone add a sample code for fifo mode with watermark? It will be nice!
Many thanks!
Hi @DSull.3​
Many thanks for your reply.
Removing this line "iis3dwb_fifo_xl_batch_set(&hAcc, IIS3DWB_XL_BATCHED_AT_26k7Hz) " the FIFO stops to work.
I set the bit STOP_ON_WTM on register FIFO_CTRL2 to 1 the INT1 started to working. Even with all those INT1 enabled, works without no problems.
// Reset the sensor
response = iis3dwb_reset_set(&hAcc, PROPERTY_ENABLE);
do
	response = iis3dwb_reset_get(&hAcc, &reset);
} while (reset);
iis3dwb_fifo_stop_on_wtm_set(&hAcc, 1);
I checked with a logic analyzer and the INT1 is happening.
I'll test the results and apply a FFT to analyze the response frequency, but I think this resolve the issue.
I let you know this week.
Thanks!
3 REPLIES 3
DSull.3
Hi, not an expert of the topic, but what if you don't set the batch in FIFO? The iis3dwb_fifo_xl_batch_set(&hAcc, IIS3DWB_XL_BATCHED_AT_26k7Hz) line.
And if you set the STOP_ON_WTM bit of the FIFO_CTRL2 register to 1?
I see you also have enabled a lot of interrupts on INT1, can you try them one by one?
\Dk
Hi @DSull.3​
// Reset the sensor
do
} while (reset);
Thanks!
Hai,
Iam also working with IIS3DWB. I need to make the acceleration readings to vibration analysis parameters. How can I apply FFT to x,y,z acceleration data. Really appreciate your comments
