2022-02-10 1:17 AM
I uploaded accelerometer application from phone application and it worked well. But after a while it stopped working. It didn't connect anymore to phone application. I thought battery was depleted so I charged it for a while but still no connection.
Then I tried to upload a new firmware on it using STM32 JTAG probe but it cannot connect to that either. I'm using STM32CubeProgrammer tool for that and it gives me the error: "Error: No STM32 target found".
From what I can see the sensortile is powered on (no led blinking) abd JTAG cable connected ok.
What can be wrong ?
Thanks.
2022-02-11 7:34 AM
Hi @zamlox , did you try with all the steps described in this procedure?
I suggest you to unplug the battery when you upload the firmware.
AG
2022-02-11 7:34 AM
AG
2022-02-13 1:24 AM
Thank you for answer.
After trying several times unplugging usb cable and connecting JTAG I managed to see the device in STM32CubeProgrammer and I was able to upload a new firmware.
Problem solved.
