Coordinate system of LSM303C (LSM303AGR, LSM303AR) is right-hand?
2020-06-10 2:08 AM
I have 2 LSM303C. Measurements show that the cooordinate system of the device is left-hand, but the "Figure 2. Pin connections" in the datasheet shows right-hand system (X-axis has an opposite direction). May be I do somethig wrong?
E-Compasses
2020-06-12 4:47 AM
Hi @ILuzi.1 , please consider the picture at p.40 of the LSM303AGR AN4825 app note: this should be correct. Not sure however why the X axis on the other picture is in the opposite sense... I'll check internally and let you know.
2020-06-15 1:21 AM
Hi Mr. Eleon Borlini. Thank you so much for your quick reply. My measurements show the orientation of the axes exactly as in the illustration on page 40.
Please allow me another 1 question. I have 2 devices with LSM303C. I calibrate them using the MATLAB script. But one of the devices has an extra offset on the Z axis - about -3213 units (direct reading from OUT_Z_L_M (2Ch), OUT_Z_H_M (2Dh)). Is this offset within acceptable limits or should I replace the chip? (The second device works with an offset of about 100 units along the Z axis.)
Thank you,
Igor
