Conversion from Roll-Pitch-Yaw to Phi-Theta-Psi
‎2022-06-30 9:27 AM
The output of MotionDI algorithm is Roll and Pitch angles. How can I convert Roll-Pitch-Yaw to Phi-Theta-Psi? Thanks.
‎2022-07-02 1:24 AM
Any idea?
‎2022-07-10 9:34 AM
Hello, it is not clear what do you want to accomplish. What is your definition of the Phi-Theta-Psi and why you can't use roll and pitch.
‎2022-07-12 5:54 AM
Indeed I would like to calculate the tilt angle for an inclinometer application.
Please see the AN below:
Please see page 7 equation 6 and 7. But MotionDI output values at only one axis deviate from those when the sensor is tilted on both axes. How can I fix it?
