2024-09-09 11:18 PM
2024-09-19 08:10 AM
Hi @TIENHUA ,
Theoretically it is possible to see other liquid respect to water. The only issue is due to chemical material is present into the liquid you are referring. This can cause a damage of the gel present in the device. In case of some particles passes the gel, the device doesn't work properly. The suggestion is to test the device in desired liquid.
2024-09-19 08:10 AM
Hi @TIENHUA ,
