App Crashes when Uploading App from Expert Mode
ZoeTakacs
Hi all,
I have been playing around with a SensorTile.Box PRO and have had success in uploading the premade "apps" provided in the app itself. However, when I create a custom app in Expert mode and try to upload it to the unit, the app crashes and the upload fails. What is causing this to happen and what can be done to stop this?
Thank you!
Hi @ZoeTakacs ,
The OIS version will be updated with the functions for flow creation in the upcoming months, meanwhile you can use an android phone or an android emulator.
Thanks for your patience :)
6 REPLIES 6
Federica Bossi
Hi @ZoeTakacs ,
Welcome to ST Community!
Do you have an Android or IOS phone?
Hi Frederica,
Thanks for the response! I have an IOS phone.
Hi @ZoeTakacs ,
Perfect, thanks for the update!
I have also been having this problem. Do you know when the iOS version of ST BLE sensor classic will be released?
thanks
Brian
hazel-james
It sounds like the issue might be related to compatibility or configuration settings in your custom app. Ensure the firmware on your SensorTile.Box PRO is up to date, as older versions can sometimes cause crashes with custom apps. Also, double-check the parameters and logic in your Expert mode app—missing dependencies or unsupported features could be the culprit. If the issue persists, try a factory reset and reattempt the upload.
