Accelerometer report invalid raw data after configure some registers.
Yansu
I'm using LSM6DSV, and use it wake-up funciton, I will configure registers when wakeup, that time I got some invalid data such as "1.998665088 1.998665088 1.998665088", how to avoid it?
6 REPLIES 6
Federica Bossi
Hi @Yansu ,
Please, try to follow this example on Github and let me know if this solves your problem.
I use the same example to implement it, but still have invalid data. So I have to ignore the data if they all > 1.5 .
Federica Bossi
Hi @Yansu ,
Do you only read these values at wake up? How much data is this?
I found if I set CTRL1, the invalid data will appear, how to avoid it?
Hi @Yansu ,
Which value do you write in CTRL1?
such as: 0x09h->0x69h
