STEVAL-IDW001V1 Troubleshoot
mvvu
Posted on November 21, 2014 at 03:44
I am working with evaluation board (STEVAL-IDW001V1) equipped with the WiFi module (SPWF01SA.11), and having trouble with updating the firmware (FW) to the board.  I followed the instructions to have BOOT0 high during power up and then pressing RESET (SW1), but the board doesn't respond with a ready message on my terminal software.
In addition, I have tried a few troubleshooting options with the factory FW. I currently have a USB to UART bridge (UB232R) to try and send AT commands after the Eval Board gives the follow messages:
+WIND:1:Poweron (140128-caf4b79-SPWF01S)
+WIND:13:ST SPWF01SA1 IWM: Copyright (c) 2012-2014 STMicroelectronics, Inc.  All rights Reserved.
+WIND:3:Watchdog Running
+WIND:0:Console active
<0>
+WIND:32:WiFi Hardware Started
+WIND:21:WiFi Scanning
+WIND:35:WiFi Scan Complete (0x0)
However, the evaluation board does not respond to
any
AT commands. I've exhausted every potential issues with continuity tests on the board, testing signal transmission, and so on to no avail.
Please help,
Michael  :]
14 REPLIES 14
akravchenko9
Posted on December 26, 2014 at 14:34
Does anybody solved this issue?
I have the same problem...
Posted on December 28, 2014 at 10:40
Hi Michael,
any update from local support about the issue? Problem solved?
Hi Artem,
if you notice the same behavior, please contact tour local ST support.
mvvu
Posted on January 06, 2015 at 07:27
Gerardo,
I have not received any contact by my local rep.  Would you please try to ping him regarding my issue again please?
Thanks,
Michael Vu
Posted on January 07, 2015 at 11:21
ok
Nickname4149_O
Posted on January 09, 2015 at 02:22
Hi Michael,
I am George Vlantis, and I work in California to support SPWF01S modules and evaluation boards. If you are in North America, I'd like to schedule a time to work with you by phone. Perhaps we can start by exchanging phone numbers, e-mail addresses and our locations. Thank you.
I would like to start with updating your board with the latest firmware. Your code seems to be a year old. Also, it will verify that the RX and TX lines are still working to the STM32F103 processor on the module. I have created an improved tutorial to upgrade the Evaluation Boards that I would like to share with you. See attachments.
Cheers.
George Vlantis, Engineering Manager
2525 Augustine Drive, Santa Clara, CA 95054
office: +1.498709
e-mail: george.vlantis@st.com
________________
Attachments :
SPWF01S-141106-0950875-RELEASE-main-3.3.bin : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1Q2&d=%2Fa%2F0X0000000bmn%2FAn304ItGTvWOXRS_UqMcKHydvsH79P7BY7_GlOHz.lc&asPdf=false
WiFi_modules_-_FW_upgrading_over_UART-20140820.pptx : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1Px&d=%2Fa%2F0X0000000bml%2FDI6TM6jKxS.U3._Xc0aNdSldvkdaS5fp0p2rxbQkuv8&asPdf=false
