SPWF01SA Wind:5: Hardware Failure: 5
‎2019-01-09 5:26 AM
Hi everyone,
Sometime when I try to connect the module to a exsisting WiFi network I receive the following string from the module:
+WIND:0:Console active
+WIND:32:WiFi Hardware Started
+WIND:21:WiFi Scanning
+WIND:35:WiFi Scan Complete (0xFF)
+WIND:5:WiFi Hardware failure:5
And then the module continue to start again from WIND:21 to retry to scan in order to match the WiFi network.
Has anyone happened to the same thing?
The FW is 3.6 (the lastone)
Giulio
‎2019-01-09 8:05 AM
​Hi Giulio,
+WIND:5:WiFi Hardware failure:5 is printed when the WiFi hardware does not answer to requests. The status code 0xFF in the previous WIND:35: seems also indicating a problem in the hardware.
After the WIND:5: is printed, is the device able to connect to the network after the next scan or do you need to reset the device?
Have you checked the power supply against voltage drops?
Elio
‎2019-01-09 8:23 AM
Hi Elio,
I have already checked the power supply and there aren't any voltage drops. After the WIND:5: is printed, the device is not able to connect to the network and I need to reset the device.
Giulio
