Nucleo L152RE and S2LP: debugger connection lost with using sigfox
TMARI.1
I used nucleo-L152RE and S2LP S2868A1. My device was connected with the Sigfox network. I ran the application Sigfox push button demo. When I want to debug the code and pushed the button, the console reported to me this following message :
Target is not responding, retrying ...
Error! Failed to read target status
Debugger connection lost.
Shutting down....
I tried to solve this problem step by step with the debugger, and I found that the connection was lost when the following function was executed :
/* Call the send_frame function */
SIGFOX_API_send_frame(customer_data,4,customer_resp,2,0);
I used STM32CubeIDE V1.2.0
How can I keep the debugger connection ?
Thanks for you help!
0 REPLIES 0
