How to Interface ATWINC1500 xplained pro with STM32l46A6ZG Nucelo ?
‎2020-03-20 5:03 AM
Hey,
So i'm using the STM32l4A6ZG and and I want to implement the ATWINC1500 xpro driver so i can use the APIs to successfully connect the ATWINC1500xpro module to the STM32 Host MCU.
Can I use this driver :
https://github.com/gd91/stm32_winc1500_station_example
and change the includes from stm32f4xx to stm32l4xx ?
in that case which changes do I have to take and where to copy the following files.
Thank you,
STM32L4 Series
‎2021-10-30 7:13 PM
Hi OGaie,
I want to do almost the same thing.
I see no one has replied to your question.
Does it mean that no one has tried this?
Have you been able to test it out. Please share your experience.
Shaun
‎2021-10-30 11:40 PM
It means these type of "can I do x" and "guide me" type questions are frequently ignored because they create a lot of work, and determining these things is part of the project/path you've taken​, so be prepared to do the porting.
The universe of possibilities extends beyond the code one can copy from Google.​
‎2024-06-10 6:04 PM
Have you had any luck with this project? I am attempting to perform a similar setup.
Thank you,
Giacomo
