2022-12-19 04:21 AM
Hello. I would like to get some help compiling any project for BlueNRG-2.
I have downloaded Keil uVision5 IDE and also BlueNRG SDK from:
https://www.st.com/en/embedded-software/stsw-bluenrg1-dk.html
In my Keil, I have downloaded package for BlueNRG-2
In Keil, I go to Project->Open Project,
Then in the BlueNRG SDK that I have downloaded I go:
ST->BlueNRG-1_2 DK 3.2.3->Project->BLE_Examples->BLE_ANCS->MDK-ARM->BlueNRG-2 and open BLE_ANCS.uvprojx
I open the project and I can see it:
I simply try to build the project and get the following error:
Build started: Project: BLE_ANCS
*** Target 'Release' uses ARM-Compiler 'Default Compiler Version 5' which is not available.
*** Please review the installed ARM Compiler Versions:
'Manage Project Items - Folders/Extensions' to manage ARM Compiler Versions.
'Options for Target - Target' to select an ARM Compiler Version for the target.
*** Build aborted.
Build Time Elapsed: 00:00:00
In my target options, I see the folowing compilers available:
I have tried with default compiler 6 and I get a bunch of compilation errors:
*** Using Compiler 'V6.19', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'
Build target 'Release'
ArmClang: error: unsupported option '--wchar32'
compiling BlueNRG1_mft.c...
compiling BlueNRG1_i2c.c...
compiling BlueNRG1_gpio.c...
ArmClang: error: unsupported option '--cpreproc'
assembling context_switch.s...
compiling BlueNRG1_sysCtrl.c...
compiling BlueNRG1_pka.c...
compiling BlueNRG1_rtc.c...
compiling BlueNRG1_dma.c...
compiling miscutil.c...
compiling BlueNRG1_spi.c...
compiling clock.c...
compiling sleep.c...
compiling osal.c...
compiling BlueNRG1_adc.c...
compiling BlueNRG1_flash.c...
compiling BlueNRG1_wdg.c...
compiling misc.c...
compiling BlueNRG1_uart.c...
compiling LSM6DS3.c...
compiling SDK_EVAL_Button.c...
compiling SDK_EVAL_Com.c...
compiling SDK_EVAL_Config.c...
compiling SDK_EVAL_Led.c...
compiling SDK_EVAL_SPI.c...
compiling stack_user_cfg.c...
compiling system_BlueNRG1.c...
compiling BlueNRG1_it.c...
compiling BLE_ANCS_main.c...
compiling demo_application.c...
".\Release\Objects\BLE_ANCS.axf" - 29 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:01
I also tried with to select V6.19 but it is same as above.
Could someone point me in the right direction how to solve this issue? I have read a simillar post here:
and I cannot fully understand why do we need a seperate compiler? Why default compiler that is being installed when you install Keil not good?
Is this the only option to install Arm Compiler 5.06 as it seems quite complex. You need to create account on ARM website and wait up to 5 days for their confirmation about your account...
2022-12-19 05:01 AM
UPDATE 2
I have tried to download Attollic TrueSTUDIO and open project from TrueSTUDIO IDE.
When I try to build the project, I am getting a message:
**** Build of configuration SPI for project DTM ****
Nothing to build for project DTM
I have tried to clean the project, but nothing is displayed on the console.
