2018-06-04 2:21 AM
my iPhone doesn't connect to the SPWF04 in mini ap mode.
I see a DHCP reply of the module, so the iPhone is partially connected, but I never get the wifi symbol on my iPhone. Also in my iOS wifi settings, it shows me always that it tries to connect to the network and I never get a hook beside the SSID name.
With the SPWF01 module I don't have this problem.
Does anybody else have this problem?
BR,
Flow
2018-06-05 2:30 AM
Hi Flow,
please try rebooting the SPWF04 after configuring it as AP.
Regards,
Elio
2018-06-05 5:57 AM
Hi Elio,
thank you for your reply.
Rebooting works for Android and WIndows but doesn't solve the problem with my iPhone.
Regards,
Flow
2018-10-18 5:14 AM
You can Check your connection, Check System Status, Update your account, Update your software and Check the date and time for this issue. still, Have any issue? then you can contact iPhone Support Number regarding all iphone issue.
https://www.applemacsupportnumbers.com/iphone-technical-support/
