2015-10-15 11:42 AM
It is possible to configure a RTC using the low speed clock? Any document? regards, JM2015-10-22 08:05 AM
Ciao JM
what you mean with ''configure a RTC'': do you want to provide a 32 kHz signal externally to the BlueNRG?RegardsDino2015-10-23 05:15 AM
Bluenrg does not contain user-accessible real time clock. You can record a fixed date in the IFR register. And that's all.
