2015-09-17 1:29 AM
Looking at the examples provided with X-NUCLEO-IDB04R1 I found it difficult to understand all the layers and protocols.
If I want to establish connection with a device and send/receive some data - what function should I use? what files should I look? Is there a manual explaining how high level functions work and what functions I need to perform different tasks?2015-09-17 7:39 AM
Dear Customer,
If you want to have more info, you can see the document:
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00099259.pdf
and you can download the package at the following link:http://www.st.com/web/en/catalog/tools/PF261967
The package contains some examples, for example chat, that show how to connect two devices and send/receive data.Regards,
Graziella Marchese2015-09-17 8:00 AM
2015-09-17 8:23 AM
Pleas see the documents:http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00114498.pdf
and the documentation inside the package. Regards, GM
