BlueNRG-132 Code development and debugging
JHall.4
Hi, I am new to the BlueNRG family and have been struggling to find the currently recommended development environment. I read that the STM32cube environment does not support it, so I have downloaded the last Atollic version (9.3). This does seem to successfully compile the example BlueNRG projects, but I cannot start a debug session with the STLINK V2, which gives error "Reason: ST-LINK: Could not verify ST device! Abort connection."
I have experimented with openocd unsuccessfully (invalid command name "WriteDP").
I am however hopeful that I have a valid hardware setup as the BlueNRG ST Link Utility seems to successfully connect to the target).
Please can someone advise a fix to any of the routes I've already tried, or let me know if some other avenue is the current recommendation for developing code on this family.
Many thanks,
James
0 REPLIES 0
