Appears and disappears
MLuna.1
hello I have purchased the steval-idp004v2 board and when I connect it with GUI V2 ST and with the TE concept IOlink application, the same error appears master application 6148 Appears i Disappears. Thank you for response
Eleon BORLINI
Hi @MLuna.1​ ,
did you installed all the drivers for the application on your OS? Can you see the steval-idp004v2 board VCOM port?
-Eleon
LMarg.1
I have the same problem. I already installed the drivers, and i can find the board on COM ports.
Did you find a solution ?
Here is an image with the error message :
_legacyfs_online_stmicro_images_0693W00000DljvSQAR.pngThanks !
