2020-12-06 2:07 AM
hello I have purchased the steval-idp004v2 board and when I connect it with GUI V2 ST and with the TE concept IOlink application, the same error appears master application 6148 Appears i Disappears. Thank you for response
2020-12-11 8:50 AM
Hi @MLuna.1 ,
did you installed all the drivers for the application on your OS? Can you see the steval-idp004v2 board VCOM port?
-Eleon
2021-08-31 5:29 AM - edited 2023-11-20 9:16 AM
I have the same problem. I already installed the drivers, and i can find the board on COM ports.
Did you find a solution ?
Here is an image with the error message :Thanks !
