vl53l5cx_set_VHV_repeat_count not found
PBoer.1
In the guide to using the VL53L5CX multizone Time-of-Flight ranging sensor it's described that for periodic temperature compensation the function vl53l5cx_set_VHV_repeat_count has to be called.
I can't find the function in any header or c file.
lukaskn
is it possible that you using an outdated VL53L5 ULD version, which does not match the documentation? The vl53l5cx_set_VHV_repeat_count function was introduced in version 1.3.11 of the L5 ULD and cannot be found in older ones.
1 REPLY 1
lukaskn
