2024-07-23 01:34 AM
i am using both the VL53L5 and L7 in a quite limited space, where the sensor need to run in the 8x8 continuous mode. Therefore, the thermal design is quite challenging. So, my question is: what temperature does the sensor specifically deliver with the parameter "silicon_temp_degc"? Can it be assumed to be its junction temperature? If not, can a delta between silicon temperature and junction temperature be estimated?
