First sorry for the delay. I was checking internally.
So to be able to get a good measurement the bottom of the water tank has to be very dark. It will avoid the refraction of the photons.
To do water tank level measurement you can use either :
- the VL53L5CX which is a multi zone sensors. In this case, take the results of the zones with teh higher photons return to get the perpendicular return (less refraction)
- the VL55L4CX which is a single zone sensor but with a narrow Filed of View.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
