2022-11-03 11:21 AM
I have read that ST will be releasing code to show how to do gesture recognition on the VL53L5CX, when is this due to be released?
2022-11-06 06:48 AM
That is the theory. However I have NOT done this myself. There are just too many MCUs out there.
But that STSW-IMG035_M0p is compliled for that version of Cortex, so all you need to do is figure out how your IDE imports a library.
People do it all the time - you should be fine.
2022-11-05 04:13 PM
It's up already. Go to ST.com and search for the word 'gesture'. There are 2 results. Pick:
It's the one you want.
2022-11-06 03:42 AM
Thank you!
I would like to use this with MicroPython on the Raspberry Pi Pico W (Cortex M0+), using the Pimoroni breakout for the VL53L5CX.
Is the firmware in STSW-IMG035_EVK and the code in STSW-IMG035_M0p all that's required? Creating a port for this is (currently) beyond me, but perhaps I can find someone who can do this.
2022-11-06 06:48 AM
