Using A-GNSS to improve TTFF
‎2023-11-06 5:29 AM
Hello
I am interested at looking at the Teseoo-LIV3F for a application but I require a very fast TTFF. Having read up on the A-GNSS option will this be available any where or any location in the world as long as the server is accessible ?
So no matter where you are as long as you can access the A-GNSS server the TTFF speed should improve considerably from up to 35s for COLD START to a few seconds after accessing and relaying the relevant data / information ?. The ephemeris data obtained from the server will be valid for your location and your sky ?
thanks
cab
- Labels:
GPS
Positioning
‎2023-11-06 11:56 PM
Hi
On Autonomous AGNSS there is no AN (but it's enabled by default in the module)
On Real-Time AGNSS you can have a look at:
https://www.st.com/resource/en/application_presentation/teseo-3-quick-testing-guide.pdf
Francesco
‎2023-11-06 6:30 AM
Hi
with LIV3F supports you have the autonomous AGNSS (which doesn't need any extra data)... the modules will learn the satellites orbit and it will use the prediction to provide a fast TTFF.
The Real-Time AGNSS is based on data coming on the internet server and it's for free on LIV3F. From the server you will download all the satellites information for all locations
‎2023-11-06 12:39 PM
Thank you Francesco - is there an App note on this feature ?
Hi
Francesco
