GNSS positioning
Ask questions and find answers on Teseo GNSS positioning solutions. Discuss NMEA sentences, SBAS activation, and signal troubleshooting.
Resolved! TESEO VIC3DA
Hi,How to know the TESEO VIC3DA module work correctly in designed board ?Thank you very much
TESEO VIC3DA
Hi,I am new in TESEO VIC3DA. I have designed a board communication between MCU and TESEO VIC3DA.Does TESEO VIC3DA auto send NMEA sentences to my MCU through uart peripheral ? Thanks
Resolved! Teseo LIV4F output data rate configuration
Hi all,I have been doing some experimentation with a LIV4F module and am trying to configure the device for a 5Hz data output rate. I see the device supports up to 10Hz.The commands I have tried via teseo suite are:$PSTMSETPAR,1190,0.2 followed by $P...
AlexT by Associate II
  • 3577 Views
  • 4 replies
  • 3 kudos
Teseo-LIV4F
Hi team,    I already have this module-Teseo-LIV3F( https://estore.st.com/en/evb-liv3f-cpn.html ) But i need communicat the L5 band NAVIC signal. In this module not supported the L5 NAVIC signal.In this module-Teseo-LIV3F( https://estore.st.com/en/ev...
Aravind by Associate III
  • 4082 Views
  • 7 replies
  • 1 kudos
NAVIC MODULE REQUIREMENT - Other wireless technologies forum
  Hi Team,  i have a query regarding the NAVIC module. Just like GPS module there is made in India navighation called as NAVIC. I wanted to know whether TI can provide me the module or EVT(EVALUATION KIT ) of NAVIC. Thnaks and regards, Aravind.S.R
  • 3059 Views
  • 4 replies
Firmware update for IRNSS,Teseo-LIV4F
Hi team ,     How to configer the firmware update for IRNSS and how to create a binary file.Firmware update which software is using?and any breakout board avaliable (Teseo-LIV4F) Thanks and regards Aravind
  • 1266 Views
  • 1 replies
Resolved! Using A-GNSS to improve TTFF
Hello I am interested at looking at the Teseoo-LIV3F for a application but I require a very fast TTFF. Having read up on the A-GNSS option will this be available any where or any location in the world as long as the server is accessible ?So no matter...
TESEO-LIV4FTR
hi team,         Any breakout board avaliable for this module(TESEO-LIV4FTR) and sugess the antenna for this module. thanks and regards aravind.s.r
  • 1533 Views
  • 0 replies
