Where should I report errors in ST documentation/Appnotes?
BarryWhit
Lead II
- If someone's post helped resolve your issue, please thank them by clicking "Accept as Solution".
- Please post an update with details once you've solved your issue. Your experience may help others.
STTwo-32
Hello @BarryWhit
You can report any typo or error on one of our documents in one of our community forums depending on the use case, product,. You have to create a post with all details. A post for each error will be better so we can report it and correct it easier.
Best Regards and thank you for the interest that you are giving to ST documents. We are always here to help.
Best Regards.
STTwo-32
3 REPLIES 3
STTwo-32
Hello @BarryWhit
Best Regards.
STTwo-32
@STTwo-32 wrote:
You can report any typo or error on one of our documents in this community.
In that case, 'Documentation' needs to be enabled as a "Label" in this section:
@Andrew Neil , enabled! ;)
