2024-03-19 01:04 AM - edited 2024-03-19 01:05 AM
I was typing a reply to a post, when suddenly the following red message appeared (before taking the screenshot, I erased the relatively short text I had already typed there):
After reloading, the thread had a post from other user, which was not there previously. However, I've encountered previously that threads I was commenting on had seen comments from other users meantime. Also, the text of that message nor its appearance (red = something went very wrong) does not reflect this event.
2024-04-09 01:31 AM
'fraid not - I just saw it, thought "oh, that again", and moved on ...
2024-04-09 10:01 AM
Generally occurs when someone edits or moves a post from under you typing your response.
Encounter it a handful of times, usually when ST staff are responding or moderating.
I too generally just cuss and move on.
2024-04-09 10:04 AM
Yeah Khoros ain't fixing anything..
ST really needs to get some penalty clauses in their contracts so their suppliers are motivated to fix problems and deficiencies in a timely manner.
Swimming upstream in molasses..
2024-04-10 07:29 AM
@Lina_DABASINSKAITE wrote:Can you share the links of those threads you faced the issue?
It's just happened again (15:19 BST):
After that, I could carry on composing my reply, but the 'Reply' button wouldn't work to actually post it.
The only escape was to refresh the page - which lost everything I'd written :frowning_face:
(fortunately, I expected that might happen, so saved it to Notepad).
2024-04-13 06:38 AM - edited 2024-04-13 06:40 AM
2024-04-13 06:53 AM - edited 2024-04-13 06:54 AM
Note, that the link in your screenshot is different:
so some moderator probably moved the thread to different "subforum", and the red message is likely to be a consequence of that.
Yes, it's very annoying bug, clearly stemming from lack of Khoros' experience with real fora.
2024-04-13 08:55 AM
This one was annoying because I did lose all I'd typed.
:frowning_face:
