Portal
s.waddingham
I have registered and validated my email, got as farr as choosing a password but then an error happened. Help please
14 REPLIES 14
mzimmer
Lina,
I am on https://my.st.com/stparc
I can enter my username and password and then when I click enter I get to the screen noted previously.
Thank you in advance for any help on this.
I continue to have this same issue.
the url is https://my.st.com/stparc
Hello @mzimmer ,
Thanks for clarifying. I am checking this case internally and I will inform you once I get some news.
Lina
Hello @mzimmer ,
I have an update here.
That link (https://my.st.com/stparc) you are trying to get to is called the Vendor Portal for things like invoices for work done for ST.
They shared the attached handout showing where to register (separate from just a standard myST account) and most importantly it shows their direct email address as well, which is:  apitaly.esas@st.com
Please check the manual and contact the team directly if necessary.
Let me know if it helps,
Lina
Hi Lina
I have access to the portal now.  Thank you.
