When I use stm32cubeMX to generate a project, using keil to compile it fails?(It is about x-cube-AI.)
2023-05-27 6:52 AM
2023-05-27 6:53 AM
How should I solve this problem? Thanks in advance.
2023-05-27 10:44 AM
A good start for solving such issue is reading and trying to understand the compiler error messages. Often they are helpful. "It fails" isn't a good enough description.
2023-06-09 10:28 AM
Hello @pzhu.1 ,
Could you please share more details on your issue (error message with screenshot), your setting project, and code generator.
You can follow the Getting started with X-CUBE-AI Expansion Package for Artificial Intelligence (AI) - User manual.
Imen
Imen
