What is the minimum hardware platform needed to develop an algorithm without using the SensorTile.box?
2020-07-07 11:46 PM
[webinar - Program decision trees in sensors with a Machine Learning Core]
Machine Learning & AI
2020-07-07 11:48 PM
The minimum hardware required to use the MLC feature is having one of the "X" devices embedding it. Check the following page for more info on the products: https://www.st.com/content/st_com/en/campaigns/machine-learning-core.html.
The MLC configuration tool available in the Unico GUI can be used offline (without any board) to generate a configuration for one of these devices.
We also provide DIL24 adapter boards of the devices embedding the MLC feature, for instance: STEVAL-MKI195V1, STEVAL-MKI197V1, STEVAL-MKI207V1, STEVAL-MKI210V1K.
Finally, for further real-time evaluation of the MLC feature, we also provide the STEVAL-MKI109V3 (Professional MEMS Tool) board, which together with the Unico GUI allows a complete evaluation of the MLC feature, from data logging to run-time MLC execution.
