Edge AI
Ask questions and find answers on how to deploy, debug, and optimize AI models on ST microcontrollers, microprocessors, and smart sensors.
X-CUBE-AI does not open after successfully installation
Hi,I'm facing a weird problem: I correctly deployed a network using x-cube-ai but now I have to add a new one.The configuration option does not open, when I click on x-cube-ai (see screenshot attacched) it stucks on waiting puntator...How  can I fix ...
Resolved! Anomaly Detection on ISPU
Hello,I am interested in implementing a static version of the NanoEdge AI Anomaly Detection for the ISM330ISNTR. That means I would like to us the trained knowledge from NanoEdge AI Studio for the library and not have to run a learning cycle after ea...
guest_7 by Associate
  • 897 Views
  • 3 replies
  • 2 kudos
How to use yolov8 on STM32H747
Hi,   I have successfully ran and trained the models in modelzoo but I would like to use a larger model with yolov8 for higher resolution.   It was mentioned in another post that yolov5 and above is not compatible with ST chips at the moment.   In an...
dogg by Associate III
  • 3675 Views
  • 13 replies
Resolved! Analyzing .onnx model: TOOL ERROR: list index out of range
 Hello,I have a large .onnx model which, untouched, I am unable to run on my STM32 board. To tackle this problem, I wanted to quantize the model in order to decrease its size. I followed the official STM wiki (https://wiki.st.com/stm32mcu/wiki/AI:X-C...
Resolved! Model Zoo: ModuleNotFoundError: No module named 'tabulate'
Hi, https://www.youtube.com/watch?v=yuSVz3x9LzE&list=PLnMKNibPkDnG9IC5Nl9vJg1CKMAO1kODW&index=3Here in this demo, the training is done using train.py. And also if you run image_classification\src>python stm32ai_main.py config_file_examples\training_c...
qaarah by Associate II
  • 2695 Views
  • 3 replies
  • 2 kudos
Resolved! Model Zoo Hand Posture and Motion Detection
Hello,I am trying to implement a gesture recognition application.I am using 53L8A1 to collect data.And found out the model zoo supports Hand Posture using 2D CNN. In the model zoo is uses minimum distance, max_distance and background distance. Based ...
Resolved! ModuleNotFoundError: No module named 'models_utils'
Hi all, I'm playing around with STM32H747I-DISCO eval board and the stm32ai-modelzoo demo. I've managed to train and evaluate a model with my custom dataset using the script in "image_classification\src\stm32ai_main.py" Now I'm struggling with the de...
croto by Associate II
  • 3021 Views
  • 4 replies
  • 3 kudos
